Problems starting out AGAIN!
GoldenEagle36
- Media
- 54
- SW Pennsylvania
- 1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
so i found a problem with my jeep. as all you jeepers on this site know, i have a AMC 304 and the hydramatic Transmission well, if its in park, for say im warming it up, i can rev it all i want, great back pressure but when i put in reverse, and hit the gas, it falls on its face. it also does that in evry other gear, except neutral. when i hit the gas, its like it floods from too much gas going in the carb, if i pump the out of it, it will hesitate, then go fine. and thats in every gear. timing is set, carb is rebuilt. i really do not know whats going on with it:dunno:
