Pulling engine, trans and transfer case
nivensid
Marshville, NC
'86 CJ7, 4.2L, T5, D300
I am pulling a AMC 304 out of my CJ5 , I have the front clip removed and just about everything unbolted. The T-15 and Transfer Case are still bolted to the engine. From this point it looks like I should be able to pull everything out as a unit. I have a 2 ton cherry picker and a load leveler.
Would you separate the Transmission and Transfer Case or pull as a unit?
Agreed. Pull as one piece. I did it when I did my frame swap. Easy. Just remove the shifter. ;)
Trans 81 CJ8
