Question on Body mounts.
Icon
whittier
CJ5, 1976 232 6Speed
In trying to remove these, of course I broke some and got maybe two out. I was ondering, when the bolt breaks. Were is it breaking? I can't see how it looks ontop of the mount. So is there a nut that sits ontop of the frame or is the frame threaded and that is where it breaks?
I'm trying to get a better understanding on where I need to drill or cut the bolts out.
Thank you.
So is the nut stripping? Or breaking?
The bolt is more than likely rusted and snapped. Or it could be stripped. Pa shows a nice photo. The nut is captured by a cage of sheet metal. The nut floats within the cage. You might consider running the bolt all the way through.
Pretty tough to drill and retap the floating nut.
