Quick h.e.i. ?
Do you unplug that motorcraft box on the inner fender when switching to the h.e.i? If I left it connected would it cause the Jeep not to start? Thanx guys in advance
You do away with the stock Ignition box.All you need is a 12v keyed power.
There is no reason to keep the stock ignition box with the HEI
Put 12v right from the battery to see if its getting spark.Unplig the wire if it runs.Then find the keyed source.
I Glad I went with the TeamRush upgrade
The module is inside the cap.View attachment 1430in this pic it says "Dyna Mod" .
kickin; you should be scolded for changing the subject and not contributing to the solution. The man is obviously having a bit of a problem and we all know how frustrating this kind of thing can be.
Now, that said, I agree 100% the TFI conversion was a lot easier and produced a much hotter and more dependable spark for less investment of cash and time.
Here is everything I have on both upgrades, in the hope that there is some thing here that will be of help
Junk Yard Genius.com 'Stealth HEI Page
HEI or TFI?
TFI ignition upgrade - Jeepz.com
1977 Jeep 232 MotorCraft Distributor Conversion - JeepHammer
Glad to be of service.See, learn something new everyday, thanks for straightening me out LongHorn
