reccomendations on some parts
canuckcj5
british columbia,canada
76 body,81 frame, bored & stroked 366ci, d44/M20, chromoly everything, 35`s d300 twin sticked with 4.1,np435 trans,locked front and rear on 35`s
Stripped off the distributor &cam gear on my amc 360, figured since I'm in there, I'll replace the water pump, timing chain set,
I was gonna order a hardened iron set of matching cam and distributor gears from bulltear.com, you guys have any preference on timing chain sets? Which I should stay away from? Good brands? Same with water pumps as well, I've always used Bosch waterpumps and had good luck with the so far on other trucks,
Any info would be appreciated, thanks,
Nick
Here's a couple pics of the can and distributor gears
American.
TRW is what a use for timing (w/Sealed Power Overhaul Set), Cloyes, Melling or what ever you want.
Bosch = stick with it.
Dizzy matched set good, never run iron to bronze or stock.(looks like what happened)
:us:
Ordered a hardened matchet set of can/distributor gears from bulltear, then oil pump repair kit,water pump,timing set from rock auto, it'll be here on the 12th :p
Thanks again :)
Got it all in, got it all on, all I got left to do is torque the harmonic balancer down, install a spark plug, put oil and a filter in and I'm ready to rock! Well auctually I'll be spinning the jeep around and cutting the model 20 out and putting a D60 in lol
With the missing metal-Do an oil and filter change PDQ.
