running hot
running hot
tn trooper
dover tn
1985 cj-7 304 v-8 3 spd. dana 20 t-case.
hey guys I got a problem, I put a new thermostat in my AMC 304 . When it's running and not moving it gets hot and pegs the temp gauge. It blows anti freeze out the radiator overflow hose. but when I drive it for a little while it cools down the needle on the temp gauge reads about half way. What's wrong and how do I fix it HELP.
Check to see if you installed the thermostat correctly...
Sure could. The "pill" goes to the bottom.
the way i remember is the spring part of the t stat goes into the engine.
You guys were right I had the thermostat i upside down. You really can't fix stupid.
No, but you can learn from it. And that's what this place is all about :chug:
glad you got her fixed!
