Rustoleum
Rustoleum
cj77
miami
Jeep cj-7 6 cyl 258. 1977
Hello
I want to know if the rustoleum epoxy paint spray and cold galvanizing are good or not?
thanks
It's more about the prep than the paint. Rustoleum is one of the cheaper and readily avaiable products on the market. I used Eastwoods rust encapsulator and POR15 chassis black. There are other products as well. None will totally prevent rust, but some are better than others. I think you get what you pay for here (IMHO). But prep is everything! Rod
What are you painting? The answer depends on what it is. For a lawn chair that sits in your garage most of the time...its just okay. On a car...meh.
Prep is very important, but at the same time, it won't turn rattle can Rustoleum into PPG.
Hi
to paint wheels ok with rustoleum? I don´t have air compressor.
thanks
any aerosol paint is going to be super thin,even with several coats..as stated above,I don't think much of aerosol when it comes to vehicles...as far as for wheels,probably not a big deal..go for it
I used it on my wheels and it is holding up just fine. As everyone else said prep is everything.
I would not do body work with Rustoleum but just about anything else.:D I spray it from a gun and thin it with acetone. It is easy to match on things like bumpers so touch up is a snap, if you are so inclined.:cool:
