Sensor on Trans and Plugs in T/C
Colo Dean
- Greeley Co
- 74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
Cleaning everything up and I see 2 plugs on the Transmission . One on the rear with 2 wires which I am sure is the switch for the reverse lamps. There is another single wire connected on the top of the Transmission which the other end is not connected to anything. Any idea what it is for and where it needs to go?
Also found these 2 plastic plugs on the t/c. Should these have pipe plugs or something in them? Haven't removed them but will be taking it to steam clean everything this weekend and don't want fill it with water.
Thanks for your help.
Oh also on the spring/ check ball issue the check balls ride on the bottom of the shift rails and the spring is under the ball down inside the housing
