shift rod and output shaft shift fork issues
stevenalex
- el paso, tx
- '78 CJ5 - 258 cu inline 6, T-18 trans 5 spd,
'10 Wrangler V6
Somehow in our process of putting the transfer case back together the shift rod output shaft fork and the front output shaft shift fork have expanded and are not fitting properly. I have called around for new parts and am having no luck. I call Novak and they said I could convert to a twin stick shift rod but they had no solution for the shift forks. Does anyone have any ideas?
