speedometer cable 78 cj7 w/ t18a trans
docs454
Rockingham NC
cj7 304 t18a amc 20 354 gears bds lift edelbrock dualplane intake holly 670
as the title indecates I need a spedo cable none listed at napa store for 78 CJ7 . I was hoping that they were the same across a number of models and would like some help please
Google one or all of these Jeep part numbers.
Crown has them and will give you the overall length as well.
They can be ordered/obtained thru several sources.
For info, the factory book says J5351777 should work for your year/application.
J5351775 64" length
J5351776 80" length
J5351777 69 " length
J5351778 60" length
please tell me more about this factory book as i have not seen one.
Jeep factory parts manual
they show up on ebay once in a while
others have copied and posted on the 'net
Locate a speedometer repair shop in your area. They can make you one up to the proper length and with the proper fitting on each end.
Yes, by a few inches, the cables I'm familiar with had plenty of slack in them to make up for a few short inches. After all a Jeep isn't high tech. That is with a stock Transmission , others well, who knows.
Trans 81 CJ8
