Spinning bearing sound?!?!?!?!!?!?
MI79CJ7
Well here is my first post and it's about a repair, go figure, right?
What I have is a sound behind the engine that basically sounds like a bearing rolling around in the dryer. The sound increases with acceleration.
The sound started when I had to accelerate quickly on the e-way to get around a car. The sound is not present at start up or idle, so I don't believe it is an engine issue. If you just do around town cruising, it doesn't usually present itself, unless you have to accelerate quickly.
I am guessing maybe a drive-shaft related issue or dreadfully a Transmission issue.
I appreciate any guidance y'all can give, thanks in advance.
