    Thank you for your support!
split window question
BradW
Wenatchee, Central Washington.
58/79 frankin CJ5 (mostly 79 renegade but will be 50's retro with 79 running gear). 59 Willys wagon (daily driver), 55 Ford Mainline, 73 Cougar convert, 63 VW bug, 46 Packard Clipper, 32 Ford truck. 2009 jeep Wrangler 4 door. 86 Toyota Corolla
I have what is supposed to be a 56 windshield frame that came with a poorly fit one piece glass, I like the looks of the split window and wondered if the rubber gaskets I've seen are all that is needed (other than the glass) or is there a metal support or something that runs up the middle. I guess basically I'm asking if I can put a split 2 piece window in this frame. anyone have one or know the answer? Thank you.
Brad
Yes the two piece windshield had a metal piece that bolted thru the gasket in the middle.
Thank you, I tried looking at pictures but couldn't tell. I guess I'll stick with the one piece glass.
