Spray bombing interior/floor advice
82Laredo
- Wake Forest, NC
- 1982 CJ7 Laredo - 4.2L, T5, factory 3.30's
1993 Z28 M6 - bolt-ons, cam, s-trim w/alky = 488rwhp
I'm about to replace the front floor panels on my jeep and want to go ahead and paint the rest of the floor while I'm at it. I don't want to use a bedliner product as this jeep is a cruiser for my wife and I ordered a full set of fitted rubber floor mats to protect the wear areas. I would like to use spray can primer and paint from the hardware or auto parts store, likely rustoleum products. I will prep by using the wire brush wheel on my angle grinder to knock down the surface rust and old paint. All in all the floor is in good shape.
Is it as simple as cleaning with a degreaser (after the wire brush wheel) then wiping down with a solvent to get the surface prepped, then priming with an etching primer, followed by a semigloss top coat? Should I use a clear coat on top for extra protection?
Any advise is appreciated on the process or products. I know using automotive products with a spray gun is best but I think I can get a good enough result that provides future rust protection with spray cans. What I'm starting with:
One more question regarding seam sealer, do you apply on top of bare metal or prime it first? I will be using a weld through primer around the edges of the floor pans. Thanks!
