Spray-in Liner in Fiberglass Tub?
Central PA
1982 Jeep CJ-7 350 Chevy V-8, SM-465 4-speed trans, Dana 300 Twin Stick, Narrowed and locked GM 14 bolt rear, Narrowed and locked Dana 44 front, 38.5" Super Swampers. Fiberglass tub. 6 point roll cage.
Hello all, I'm thinking about getting Line-X (bed liner) sprayed on the inside of my fiberglass 7.
My question to you guys is, has any of you guys had it done on fiberglass? I'm curious if it "sticks" the the 'glass like it does to metal. In other words I'm worried it may peel or lift off the 'glass after a couple years. Thanks.
im going to assume... that as long as you sand the fiberglass with 80 grit it should have enough grip to it and you shouldnt have to worry about it peeling or flaking. just make sure it gets sanded and cleaned properly
I used a roll in liner (Herculiner I think, from Menards) and it worked great. Sanded it down with 80 grit on a DA, wiped it out with fast reducer to remove any oils or grease and painted it on, two coats. $75.00 and done.
Thanks oldguy. I may have to try that since that is waaaay cheaper than the spray in route.
