I have a 79 CJ7 with the AMC 304 it has the ford style starter silanoid am i correct that one side of the large post goes to the battery the other goes to the starter then the smaller post one side has power and the other side should be powered when you try to start the engine? is this correct?
i have a 79 CJ7 with the AMC 304 it has the ford style starter silanoid am i correct that one side of the large post goes to the battery the other goes to the starter then the smaller post one side has power and the other side should be powered when you try to start the engine? Is this correct?
