Steering Gear Box
musciab
- Media
- 7
- Tiffin, Ohio
- 1974 CJ 5, 6 cyl 3 speed, AMC 20 Rear, Dana 30 Front
So I have run into more problems, even before I had a chance to look at the spitting issue that I posted about last week. So my steering has a ton of play in it and it is from the steering gear box splined rod that connects to my steering coupler. I took a look at it last night and found that the splines are no more and the only reason I have any steering is because of the screw in the bracket that hold the coupler to the box.
My question is, seeing as I am broke right now and getting married in exactly a month can I do a quick fix for this. Meaning, can I just go ahead and drill a hole through the coupler and splined rod coming out of the box and put a screw through there then replace the bracket for extra support incase something fails? Will this work for just putting around town and getting me to work a mile away until I can afford to replace the box?
Does anyone have any good contacts for used CJ5 parts? Or has anyone seen a steering gear box for a 76 CJ5 AMC 258 i6 / 4.2l with power steering? I think I found one on craigs list but it is for an 80 CJ7 . Are these interchangeable?
