Misc Suspension issue?
Tommydp
California
74 cj5
Hello,
I mentioned in my last message I recently purchased a 95 yj. It had 2-1/2” suspension lift and bushings etc were worn out so I put a new rough country 2-1/2” lift with new shocks.
It was leaning to passenger side 1/2”-5/8” before lift change and after new suspension it still has the same amount of lean. Any ideas why?
Maybe the body mounts are shot. The rubber mounts can crack and collapse overtime.
Do you have a front sway bar ? I know when mine is disconnected mine looks like it’s lower on the passenger side as I’m driving down the road. I need to measure it when connected and disconnected.
Check the distances between shackle hanger and spring hanger on front and rear. Left and right should be the same measurement.
Could have some differences though as a result of a crash/bad Chrysler quality/modification/etc.
I’ve also seen differences in aftermarket spring lengths too, which will also cause the lean.
$20.00
  10.0%
