    Thank you for your support!
T-150 ?'s
T-150 ?'s
scooter6529
Waupaca, Wisconsin
1977 CJ5 304 V8 pretty much stock so far !!!
2013 JKU Sahara Wrangler, 2" lift on 33's
Hi all,
I've been restoring my 77 CJ5 since August 2012 in that time I've acquired many extra parts. I converted it to a NP435 Transmission because I couldn't find parts for the T-150 . I bought 3 T-150 's hoping to build one good one but no such luck.
I guess what I'm getting at does anybody have a use for them I don't really want to scrap them. Let me know what you think. Thanks much.
They were all that bad? Did the previous owners store them outside in the rain and mud? :D Even if all the innards are toast, the cases are worth something I would think.
The case alone is @$50.
List them on all the different places and someone will buy.
Hi all,
I sent you a private message
No...they appear to have been stored inside...not too nasty...just gears torn up pretty good...I checked with a couple Transmission parts sources and they all told me the same thing parts NLA...that's when I started to research other options and found the NP435...so I went that route...Thanks for the replies fellas !!!
