T-176 Leaking significant amount of gear oil
jeepvolks
I pulled the Transmission almost a year ago to replace the clutch components. After I put it all back together, it immediately began to dribble gear oil from the bell housing. I didn't drive it for several months and pulled it back out to take a look. I decided to replace the front bearing holder gasket and the shaft seal. After the Transmission sat in my garage floor for four months I finally found time to put it back in which I finished yesterday evening. I drove to the gas station to fill up and when I got back home the leak was doing exactly the same thing. In looking at this Transmission I can seem to understand where else the oil could be leaking from. I suspect someone has seen this before and could shed some light on the situation. Just to be clear, it's an 85 CJ7 with a AMC 258 i6 / 4.2l , T-176 and Dana 300 . Thanks friends!
