T-177 guts in T-176
T-177 guts in T-176
lgbent
Morven, NC
72 CJ5, 73 CJ5, 78 CJ7, 79 CJ7, 85 CJ7
Hi, I have a T-176 Transmission that need to be rebuilt, I know where I can get the insides out of a T-177. What would I need to change to switch to my Transmission , All the gears, the input shaft and the cluster gear or just the gears? Thanks Grant
when you say "re built " do you mean the gears are broken or you just need bearings and synchronizers??:cool:
Just bearings & seals, but the T-177 is geared a little lower isn't it?
My understanding is that you can change out the internals from a 176 and a 177 - you need to be careful as not all the parts are interchangeable (cluster and main gear for instance). Take a look at the link LongHorn posted and you can see what will work between the two. The main shaft length is also different.
