Tail Lights
Tail Lights
Hoopy
North Bay Ontario Canada
1962 CJ3B.
Just trying to wire my lights. Have orange, blue and yellow wires going to the back. The yellow has power. I'm trying to install flush mount lights. They have 3 wires; a white, red and black. How do I connect them. I think the white is a ground since it has a round clip on the end. When I connect the red directly to the +'ve on the battery and the white to the -'ve they light up.
The lights that you plan to use usually go like this: White - Ground; Black - Tail Lights; Red - Stop/Turn lights. As for your Jeep, are you talking about the CJ3b ? I'm not familiar with its wire harness, but you can attach a simple light probe sold at most all auto parts stores to each individual wires while turning the brake lights on, etc. Once you get this done, connect the wires with a water proof snap connector. You'll be glad you did in the long run. I get mine from eBay, cheep but worth the effort. Here's an example: 10 Kit 2 Pin Way Waterproof Electrical Wire Connector Plug LW | eBay
:ww:
PB has you on the 'rite' path. ;)
If you're go'n to LED type. You will have to install a motorized type turn signal flasher.
Could be LED but it's hard to tell. What are the part numbers? Can you take off the rubber surrounds and open them?
Not a fan of Omix-Ada but they are about the only ones offering aftermarket (universal) turn signals for pre 72 Jeeps.
-->> Omix-ADA, 17232.03 - Turn Signal Switch, Black; 46-71 Willys & Jeep Models - JeepHut
-->> Omix-Ada, 17232.01 - Turn Signal Switch Kit, 46-71 Willys & Jeep Models - Available at the JeepHut
Many vendors sell them, this is just what I found with a quick search.
I don't know. Wire'em in and see how they work.
Does you CJ3b use a normal turn signal flasher?
Forgot to ask one important thing, do you currently have a turn signal switch?
Yes I have a turn signal. It looks like original equipment, but I don't know for sure. I don't think it works, since it doesn't click when trying to signal.
Ahh, that changes some things. Do you have a multi meter or test light. Here is a great page on 3b turn signal wiring for different switches. You may still end up needing a new switch using the links provided earlier.
-->> Turn Signal Wiring
-->> Stovebolt Tech Tip --
