Clutch TO bearing "play"
its415dave
Hayward, CA, USA
1968 Jeep CJ5. Dauntless Odd-Fire V6.
Hello,
Changing out clutch on '68 CJ5 with Dauntless Buick 225 V6 V6 and T-14 Transmission . Torn down ok, lots to clean up. PO had oil leak for awhile.
Measured for throw-out bearing. 3, 4 5 times, I'm sure it was correct. Setup adjustable TO bearing to correct measurement. Bellhousing, clutch fork with bearing bolted to block.
Before I lifted the trans I noticed TO bearing is pressed up against pressure plate spring. Seems like pressed hard, I can't move it at all.
Is something wrong? Once I stab trans up there it will move to correct space or should I take down bellhousing and start again?
Thanks for anyone's help.
its415dave
Wow! Very thorough post. The one thing I have to say is that your setup has been screwed up from the start and for years.
Since you don't drive or put miles on it was never noticed.
Let's get this corrected.
The throw out bearing should never touch in an idle position.
What clutch are you using?
Crown disc and pressure plate. Novak adjustable TO bearing. Also installing Advanced adapters chain linkage. The old was probably what you referring to above. It was a very original mess.
Like CJ stated, there should be a tiny gap between the TO bearing and the fingers. Sounds like your adjustable TO bearing may need some attention.
Or, the hat height measurement (from flywheel surface to fingers on pressure plate) with the new setup is just too tall. My recent clutch setup was just that, too tall of a pressure plate, so I had to modify the throw out fork to allow for some air gap clearance.
Yep, need air gap so the TO bearing does not drag and spin. If the bearing drags it will wear out, over heat and take out your clutch forks / fingers.
Replace the pilot bearing too.
Set your clutch pedal free travel do 1/2-3/4".
$20.00
  10.0%
