Trans swap
isn't the 98 a 4.0
and most likely not
well for sure the driveshafts are diffrent the 98 Transmission has a hydrualic clutch linkage depending on what Transfer Case you have you will have to have an adapter for it and Im sure the Transmission mount is diffrent. It would make you Cj much more street freindly if your willing to put in the effort to do the swap :chug:
