transfer case change... what to do?
concreteguy82
Clio, Mi
'79 CJ-7.....AMC 360, sm465, Rockwell T221, 14 bolt rear locked, Dana 60 front open, full width, 4.10 gear, 38.5-14.5-15 TSL SX tires, cj 4" springs, fiberglass tub, one-piece fiberglass hood/fenders, a bunch of diamond plate aluminum and some autometer gauges.
Ok here's the skinny. I have a79 CJ7 , amc 360, sm465 Transmission , Rockwell t221 tcase. 14b rear, dodge pass drop d60 front. CJ4 " lift springs. I want to change to a np205. However, the front drive shaft is going to have to be longer, and the rear shorter. This is also going to kill my rear driveline angle. Are there any springs I can switch to that will remedy this? Should I just change the pinion angle? I think the only real fix is moving the rear axle back, but not sure how to.
just move your rearend spring mounts back on the front hangers and extend the frame so you can move the rear hangers..here is mine..it is moved back 14 inches..I'm running a 350/350/208 to a 14 bolt..rear driveshaft is 24 inches center to center on the joints..
Perfect thanks!!
Trans 81 CJ8
