Transfer Case leak ?'s
1986 CJ 7 258 automatic transmission, d300 transfer case.
Found a leak seemingly the front transfer case seal.
Questions:
Manual claims it can be removed and replaced while on the vehicle. Anyone attemt this?? If so any insight as to what I can expect.
To support Transmission I can put a jack under, but what is the easiest way to support the transfercase when removing the plate?
Manual also claims I need a puller. If you did this what did you use to pull the yoke.
Thanks in advance for any help.
Rich
Questions:
Rich
