transfer case
cjnewbie
i just got a bunch of jeep parts and 1 thing that is here is Transfer Case that has spicer cast in it was this from a cj or something else
all this stuff came with a 79 CJ7 that i traded for mostly becuse i wanted the tilt wheel that it had and the power brakes so all the other stuff i am just going to sale the jeep is an automatic also are those any good?
ya personaly i perfer a stick but was just wondering about the automatics if they stand up with big tires and a little abuse
ok two questions is the 4 speed tranny the granny gear Transmission ? if so is the top gear the same as the top gear in the 3 speed? 1 more question 1 just pulled the diff covers on the new cj and the numbers 378 are stamped on the ring gear was that a stock ratio ? thanks as always for all your help sir
ok i just counted teeth and it comes out to 3:28 does that sound better for a stock ratio?
The small number is the number of teeth on pinion, the large number is the number of teeth on the ring gear.
I've never seen a 3 tooth pinion, at least they don't start out that way.
sorry ya it was a 3.28 ratio a 14 tooth pinion and 46 tooth ring gear also are the manual steering boxs any better than the power stearing ones the reason i ask is my jeep has power but i got a manual bo with this other stuff and didnt know if there was any advantage to the manual boxes other than the work out LOL
ok thanks just wasnt sure about durabilaty thats all and ya i am running 33x12.5's
