Transmission Drain
Transmission Drain
MDJEEPER
Calvert County, Southern Maryland
1986 Jeep CJ
Mostly stock, 258 c.i.d., T-176 tranny, Dana 30 front, AMC 20 rear, Dana 300 t-case, 31x10.50 tires, 2 inch body lift
As folks might have guessed, I am trying to replace all of the fluids in my project. Besides fighting with the differentials, I want to move onto the Transmission and Transfer Case . Just curious if folks have suggestions concerning draining these guys since both are obstructed by the skid plate.
Getting to the drain bolts shouldn't be a problem, but directing the old fluid so it just doesn't pile up on the skid plate could be!
As folks might have guessed, I am trying to replace all of the fluids in my project. Besides fighting with the differentials, I want to move onto the transmission and t-case. Just curious if folks have suggestions concerning draining these guys since both are obstructed by the skid plate.
Use large Transmission drain pan.
Park on a slight hill with the drivers side wheel a little higher.
It's not perfect but it works.
If that's not good enough, you can support the driveline with jackstands & take the skidplate off, but it's a PITA just to drain the fluids.;)
A little creative cutting on a milk jug usually makes it happen for me.:cool:
Thanks for the ideas!!
I was thinking of a cut up milk jug as well, or a paper plate bent into a funnel shape!
Jacking up the left front is also a cool idea!
Anybody know off hand what size allen wrench is needed for the Dana 300 Transfer Case drain plug?
Anybody know off hand what size allen wrench is needed for the dana 300 t-case drain plug?
1/4";)
