Transmission number Identification
Jeeper42
Michigan
Late 86 CJ7 Stock with a Dana 44.
YJ tub.
Still building it.
Hey Guys,
I'm trying to ID my Transmission so I can get a new 2nd gear synchronizer.
The teeth on mine are shot.
I have a 1986 CJ7 5 Speed M/T
The only numbers I found were:
sf8950010 and 2 unknown numbers.
13-52-dn 45684
But I can't find reference to any of these.
Or maybe it doesn't matter as there isn't more than once type of synchronizer for my Transmission .
Anyone have a good source for Transmission parts?
Thanks,
Jeeper42
Probably a T-5 .
T-5
Five Speed
From 1982 to 1986 the Borg-Warner T-5 was offered in CJ's as as Overdrive Transmission . As a matter of fact this was the only Overdrive Transmission offered in a CJ. The T-5 is a light duty Transmission that always came with a Dana 300 Transfer Case .
There was a heavier duty T-5 Transmission that was used in street vehicles such as Mustangs. These transmissions were referred to as World Class T-5 . They were never offered in Jeeps or any other four-wheel drive but there are companies such as Astro Performance that offer the gears and parts to rebuild the T-5 into a World Class T-5 . The strength of these transmissions is not as strong as originally hyped and it isn't recommended to rebuild your T-5 into a World Class T-5 . A better option would be to replace the T-5 with a stronger Transmission such as the T-176 or T-18 .
The T-5 is 15.25 inches long.
T-5 -5speeds-com.jpg" data-src="/community/proxy.php?image=http%3A%2F%2Fwww.jeep-cj.com%2Fgallery%2Ffiles%2F1%2F6%2F7%2F1%2Ft5-5speeds-com.jpg&hash=c73652d3e68fe091a88d04c06d60b995" data-lb-sidebar-href="" data-lb-caption-extra-html="" data-single-image="1"> t5-5speeds-com.jpg
For more information see the above post Weak Transmissions of the 1980's
Gear ratios:
1st – 4.03
2nd – 2.37
3rd – 1.5
4th – 1.0
5th – 0.86
Reverse – 3.76
Well then it looks like I have a T-5 but now I'm having issues finding a 2nd gear synchronizer.
My brother-in-law who is rebuilding the Transmission said I need a new 2nd gear synchronizer but all I can find are ones for 1st & reverse, 3rd & 4th and 5th.
He told me the teeth are warn down and it keeps popping out if second.
Is there a synchronizer for 2nd gear?
Jeeper42
The synchro hub and sliding synchro sleeve are only serviced as part of the mainshaft ( from Jeep anyways).
2nd gear and the synchro rings are available seperately according to my books.
