Trasfer Case Woes
Trasfer Case Woes
rsparks79cj7
Rogers, Arkansas
79CJ7, 258, stock BBD, HEI, T150, D20, Frt.D30 4:10, Rear Corp.20 4:10 with factory limited slip.
Hey guys, I have a 1979 CJ7 with T-150 and Dana 20 . This last winter I have been having problems with my TC slipping out of 4H. Does someone have any suggestions as to what could be causing this.
Wear-Rebuild time.
Make sure it's going all the way into gear, if it is then as LG said it may be time for a rebuild.
Do you have twin shift levers. When I got twin shifts mine also started popping out of gear. It doesn't happen only with twin shift levers. The problem is the detents on the shift rails. You can grind them down a little deeper or shim the springs for the ball detents.
Thanks guys for the info, I appreciate all of the advice. I have a single shift TC. If it's shift rail wear how difficult is it to repair. If not I guess it's time for a rebuild.:mad:
To remove the shift rails you do have to completely disassemble the Transfer Case .
The shift forks must be removed from the shift rails. And the gears are in the way. THat's why I'm saying the whole Transfer Case needs to be disassembled.
Sorry there's no shortcut.
Thank-You BusaDave9. Since I'll have to completely disassemble the Transfer Case anyway, I might as well go through the whole thing. Do you have any suggestion as to where I can find quality parts, or a kit?:)
That's why I'm here!
TCase Dana 20
Trans 81 CJ8
