Tub mounts
Tub mounts
Bear991
tiger
78 cj7 Golden Eagle,06 Dodge 2500 H.O.Cummins. 46 Dodge truck Rat Rod with Mercedes turbo Diesel. 502 big block Boss Hoss motorcycle. 84 Chevy pickup (my Grand dad's) fully restored
I've had a noise that I couldn't find till I did a few upgrades on the left front of my jeep. I found the area around the left front tub mount broken and what I was hearing was the sheet metal ends that had cracked were rubbing against each other. Is there a replacement mount that I put in place of this one? Or do I need to fabricate a patch and weld that in?
A repair would be the best way to go, I have had both my channel mounts in front of the rear tires crack so I just stuffed aluminum blocks in there.
