Tub removal 79 CJ5 - WHAT AM I MISSING???? Dangit!
ewerbeck
Florida
1979 CJ5 4.2L 258. Dana 20 T-Case, T150 3-speed manual trans. Dana 30 front. AMC 20 rear.
If you haven't figured this one out yet, you have to take that whole bar off to get the tub out. The bolt you have said you removed already and the one on the other end. That bar goes under a crossmember in the frame and has to be completely removed.
I was very fortunate that the 1980 CJ5 that I got was not as rusty as yours. You have one heck of a project on your hands.:chug:
Thanks. I'm going to look at it again later today... I did not see that it went under the crossmember... but everything is so rusted it all kind of blends together.
Those two bolts were hard enough to get out, I can't imagine how difficult the other two will be. They started 'spinning' and would not come out without me putting a vice-grip on the other side to hold it in place while working the bolt. If I can't get to the other side to hold that little square in place, then I'm going to have an even more tough time.
Perhaps it would be easier to just bend/break those two bars?
I want to put on the record that I did a one man tub removal!!!!
:cool::chug:
:cool::chug:
Congrats!:chug:
While you have it off and upside down, take you a grinder and cut the bolts off that attach the roll bar. You will see why when you try and get that off...:eek: Looking good so far!
:cool::chug:
CJ5s are easy...try the one man removal with a YJ tub some time. :chug:
Am I going to run into this on my 76' CJ5 ? Removal of this bar? I am hoping to have it removed this weekend.
:cool::chug:
Good work.. FYI I do all my work one man. Transmission swaps, axle swap tub removals. The only then I ask for help with is the windsheild removal.
