Turn Signal Issue??
Turn Signal Issue??
Shazam
North Carolina
1979 CJ-5 Renegade with '74 304 V8 & Edelbrock manifold & carb, Heddman headers & sidepipes, T-150 3 speed, Dana 20, Dana 30, AMC 20
OK, all the sudden my turn signals don't work anymore. Checked the fuse and it was blown. Changed it and it blew again. Put in a larger (20) and it blew. So then I replaced the turn signal blinker (round thing in the fuse box) and threw in another 20 fuse (I know it shouldn't be that big but its all I had left)...then the signals worked along with the headlights dimming in sync to the turn signals. They all worked except the passenger rear quarter panel one. So I took the fuse out while I figure out whats wrong. Anyone have any ideas? I'm not electonically minded so please use layman terms if possible. Thanks!
Sounds like the turn signal switch in the column. I think I have had to replace it on every thing I have ever owned.
And verify all your grounds are still good. make sure you check your head light grounds too and marker light grounds.
