Vaccuum advance problems
GoldenEagle36
- Media
- 54
- SW Pennsylvania
- 1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
my jeeps vacuum advance isnt working properly.... and the distributor is before 5 degrees TDC. but the vacuum advance is pointing up instead of down towardds the fan. i dont know why its giving me trouble. the vacuum advance may be bad or i have to turn it. would it help if i turned it? i have vacuum in the line its just not advancing properly. what might be the problem?
