Vacuum help
Vacuum help
bobt
pennsylvania
1978 CJ-5 258ci/T150-3spd
I need help with a vacuum hose on my carter 1bbl on my 78 CJ5 . I just need to know where one vacuum hose goes. It is located on the front facing the radiator. See the attached picture.
Appears to be the carb bowl vent fitting.
Would have gone to the charcoal canister if I recall.
if you no longer have charcoal canister hooking it into the air cleaner would be a good place, that way the gas fumes get sucked back into the engine and one less smell to smell :D
