Vacuum hose problems
RUSTYOLE CJ5
savannah, ga.
79 CJ5, 258, 3 SPEED, STOCK RUNNING GEAR, 3" LIFT, ON 33"S
This is all new to me, but maybe someone out there has the info i need to make my AMC 258 i6 / 4.2l w/ carter 2barrel run right. To start, all i have to work with is the carb., stock air cleaner, pcv valve, hose from distributor, metal line from top of intake, as you can see from my profile, previous owner had removed everything emissions related, what i would like to know is can i make this engine run right with what i have, (it was running before the fuel system rusted out) all of that has been replaced. What needs to be connected to the carb. And what needs to be plugged off. And where does the signal for the electric choke come from? Any help or suggestions would be appreciated. My haynes manual does not help much because most of whats on the diagram is no longer there
I put a fuel regulator in line for my weber carb, but I'm still smelling the raw fuel issue going on. It also likes to puke when I put the throttle to the floor. I'm wondering if I might have my vacuum lines and/or timing wrong. Any thoughts?
thanks in advance.
Where did you mount your fuel regulator and where is your fuel filter? Any pictures?
I can gather some pics for you, but it is in between the fuel filter and the carb. The fuel filter still has the return line connected.
