Vacuum Line Help..With Pictures
CJKrawler
Old Time Jeeper
Need some help with a 360. I just got this thing, and I am trying to get it running. I was able to get it to start today, once a good battery was put in. Ater getting it running, I found a fuel line leaking
. Ran to the parts store, got a new fuel and air filter, and some rubber fuel lines. Truck started, and ran a little better, but not much. I then discovered fuel leaking from around the carb, still not good. I am assuming the issue is from the gasket, so I pulled carb off, the gasket looks decent, but I need to replace it now anyways. While pulling the carb off, I am discovering some missing/disconnected vacuum lines that may be causing this thing to not stay running. Here is what I know for sure.
Electric fuel pump was installed at some point for t/s purposes
A holley carb replaced the original 2 barrell carb, i do not know the model of it.
There are two ports for lines on the air cleaner housing, but only one was connected to anything.
The line in the first picture was not connected to anything, nor was it blocked off. I have no idea what the piece that it goes to is for.
Any help, thoughts, or anything else would be appreciated. And if there are diagrams for the vacuum system, that would be great too.
Oh, and in the 3rd picture, lines marked 1 and 2 were connected to the air clear (1), and the back of the carb(2)
![Vaccum Line 1.jpg Vaccum Line 1.jpg](https://jeep-cj.com/community/data/attachments/5/5636-f076466004f41c3bae942c958e1d8168.jpg)
![Vaccum Line 2.jpg Vaccum Line 2.jpg](https://jeep-cj.com/community/data/attachments/5/5637-6c1fee089edda658c40d4bb1ff30fcbe.jpg)
![Vaccum Line 3.jpg Vaccum Line 3.jpg](https://jeep-cj.com/community/data/attachments/5/5638-f0d7b9c61a0993438afc40cdb64760a8.jpg)
