Warn AMC 20 full floater hub removal
JamesBryan
Layton, Utah
1985 CJ7. LS1/TH350, ARB's front and rear, Warn full floating AMC 20 w/SSBC disk brakes, Ramsey 9000 winch, Custom Paint w/ghost flames
the round "washer " with the 4 square notches in the edge, is actually a nut.
takes a special socket to fit the notches. available at most parts houses, honest.:cool:
Yup Io's got it! Spindle lock nut shown in photo 1. pretty much as found on your front axle but not hex shape.
Thanks guys. I'll go looking for one tomorrow...
It will be a lot easier next time. I use a 3/32 welding rod with a bend in the end to pull the washer out. If you dislike the axle please let me make you an offer on it.:D
what gear ratio do you have??:cool:
I am curious about the disc brake set up. What do know about that?
To say that this has been an experience....The calipers are from a 89 Chevy Camaro.... WTF? The pads from SSBC do not fit. Got the correct pads from Auto Zone by going through many boxes and cross ref. the calipers. And now the rotors are too thick. Just a hair.....So I got a rotor from Auto Zone for a 78 CJ, and its too thick. Any ideas on rotors...
There were 76-78 rotors that were 1-1/8" thick and 78+ were 7/8" thick.
I run 78 Monte Carlo calipers with the 7/8" rotor.
In the photo of the washer, at 11 o'clock see the pin on the inner locknut? That's why the washer has all those slots. I use 2 magnets to wiggle it off. The outer acts as a jamb nut.
Well after messing with this for more than I cared to. The calipers willl not fit over the CJ rotors. Who knows what the previous owner had on this. So I decided to just buy some SSBC rotors and redo the disk brakes. I've gotten real good at getting the Warn hubs off :D
Thanks for all the help on this. Maybe I'll make a thread about installing the new calipers when I get them in.
$20.00
  10.0%
