What to seam seal from bottom?
82Laredo
Wake Forest, NC
1982 CJ7 Laredo - 4.2L, T5, factory 3.30's
1993 Z28 M6 - bolt-ons, cam, s-trim w/alky = 488rwhp
I'm going to seal down the side in pic 1 and the rounded edge in pic 2 (with the :dung: tack welds; had more gap than I realized after plug welding the entire topside)
It is completely seam sealed and epoxy primered up top.
I would not 'cap' those ends at all.
Leave them open to 'breath' and dry.
All of the above..........seam sealer is OK .........But I would still finish tack welding that panel on from both sides , otherwise your floor will be flexy and whatever sealer you use down there will crack or loosen later...., then rattle can some spray undercoating into and around all of those seams under the floor.......dust, turns to dirt, then mud and once inside a seam and left to be wet & damp between those areas will rust through your metal once again.........fixed many of them. Weep holes are also a good idea in Blind areas to let the moisture out. Good Luck!
:D:D:D:D
Why not seal all of it, I would and leave very deliberate places for unwanted water to drain out. Sealing all the seams leaves fewer places for rust to start or grow.
My father was a electronic engineer who designed and built equipment (some that went on the space shuttle) and always said that you leave a hole at the lowest place for water to escape. Their is always water (especially in the air) that can condense. The only way to completely eliminate water is to completely seal it air tight than pump out the air (basically create a vacuum). If you seal all the seams completely you will trap water and rot out these lower sections.
$100.00
  50.0%
