    Thank you for your support!
What to Use?
What to Use?
Vick68
South Carolina
1973 Cj5 71 AMC 360 4 spd Manual Front & Rear lockers,
1999 F250 extended cab 5spd Triton V10
Hey i'm just wondering what do I need to use in my tc, tranny, and diffs. Do I use dope in the dips? And manual tranny fluid or what. Thanks in Advance.
Use 80W-90 in the tranny, TCase and diffs.
If you have Limited slip diffs you need an LS additive.
EDIT: you say you have Manual Front & Rear lockers. I assume you mean selectable lockers you can activate. No they don't need a LS additive. Use the same 80W90 in all the mentioned places.
