whats the diff?
josh84diffenbach
will the ring and pinion, just the ring in pinion not the carrier from a early off set 19 spline taperd dana fit the 30 spine carrier or vice versa, is there any differance in the ring an pinion alone
Short answer is Yes it will accept the same ring and pinion gear but to install it you need to adjust the shims to make sure you get the pinion depth and backlash set correctly.i was woundering if the 4. and up carrier of the Dana 44 30 spline in later years will accept the same ring gear and pinion position
