wheel joint?
dalefan88
Crazy Sr. Respected Jeeper
- ada,oh
- 79 cj5 258, t150, dana 20 transfer case, dana 30 front, 20 rear,warn hubs,2.5" procomp lift,teamrush,msd box,mc2100 carb,hedman header,clifford intake,optima battery, ford shock towers.
i been fighting with the wheel joint on the driver side front of the jeep. its a Dana 30 . the first u joint i cracked a cap putting it in. the second joint i get on the axle and the caps stick out and wont let it slide through the spindle. i guess friday i will go and buy our expensive one. i didnt want to get this one cause you can grease it. hopefully this one will be right. anyone ever have this with your wheel joint and where do you get them from. thanks.
