where did you mount you toggle switches?
bzahler
Wisconsin
76 CJ7 304, turbo 400,Dana300,dana 44 front,dana 44 rear SS twin stick 4.5 Rubicon express lift,Warn8274,
:banana:I am looking for ideas on where to put some toggle switches for the winch and extra lighting. The only thing I can come up with is mounting a alum. angle on the bottom of the dash under the speedometer. Not Shure I like that idea. Anybody put anything on the bottom of the windshield?
I Would suggest using the toggle switch that came with the winch controller along with a safety switch to keep unwanted fingers off. Mounting it under the dash is a good location to start with as you can move it to a different location if you feel it should be somewhere else.
Can you post a picture of your dash?
I may have had more unused real estate than you, but this is what mine looks like
Extra lighting
Marine grade on/off switches
-Jon
safely tucked away.:D
Thanks for the replies. Torxhead I do have a guarded switch and two pushbuttons for the winch that I got from the 12volt guy. IO I had thought about putting them in the center console but didn't know how to run the wires in a clean way. Can you explain how you ran your wires? :chug:
Custom dash in the assembly stage:
Here is my custom console
I made a plate that replaced the radio ( can't hear the radio anyway) and placed four switches on it.
