Electrical Where does the wite wire on my alternator go?
ahelwig
FLAGSTAFF
85 CJ5
I have an 85 CJ7 with a 350 in it. Im trying to clean up the wiring hacks that the PO had done. I also just put in speedhut guages so I cleaned up my dash wiring as well. My alternator has a large red wire coming out of the back then on top there is a plug with a white wire with a diode and a red wire that ties into the red wire coming out of the back. Im just not sure where to run that white wire with the diode. I understand what the diode is for. I do have a loose white wire in my engine compartment and it says "XLPE (its hard to read but I think these are the letters) RESISTANCE DO NOT CUT". ANother note is it seems to be a smaller gauge than most of my wires in the engine bay and it is a solid wire (not stranded) It goes into the firewall plug and from what I can tell changes to a tan wire labeled GEN LMP that goes to my fuse block and is screwed into the GEN LMP location.
SO does the alternator white wire connect to the skinny white wire that says "do not cut"? The alternator white wire is a different type (stranded maybe 14 g) than the engine compartment (very thin solid wire).
Thanks!
$100.00
  50.0%
