which carb do I have... here is a picture
Jeepsrule
Georgia
1984 CJ-7 Laredo (no modifications)
(straight -6) 258. Engine is original.
no major changes except tune up stuff
Manual - 5 speed (4x4)
I know it is not the orginial. I just don't know. Thanks for your help.
If I need to take more pictures let me know. Thanks!
Thank you... I actually have had very good luck with it over the years. I have almost 190000 miles on the engine. I believe the carb was replaced around 1990. Many the miles are highway miles. Trying to keep it all orginal, but i am currently doing the first half of Team Rush upgrade. Autolite -985 .035 gap. Got the wider cap and adapter and rotor... Just upgraded the wires too and got the stock ignition coil for $21..
Just got the Charcoal canister that rollbar suggested on his post. Next checking all the hoses. Vacuum canister looks good. In about a year I will do the second half of the Team Rush Upgrade...
hey. i have the same carb and dont know what all the ports on it go to. do you think you could help me out?
I am learning them as well.. I did find some pictures. See attached. I will certainly try to help, and I am sure others on here will help as well.
That is the infamous Carter BBD computer controlled carb. It was used from '81-'90 in the 258 CJs,Wranglers, and a few others.
I think it might have been 1983 and up. My 82 has the Carter BBD carb but not with the computer controlled thing-a-ma-bob on the backside or the computer under the dash. Could be they started with them in a couple states like Ca. in 81.
Vacuum=confusing. i need warm weather to finish them
