why not a spool
why not a spool
cymbash
camden ar
1980 cj-7 amc 360 4 speed 33.12.50.15 swampers
does anyone make a spool for 4.11or 4.56 gears for jeep model 20 rearend. the ones i found 3.08 is the lowest i found.
i thought you had to change the carrier when going to lower gear such as a 4.11 or a 4.56
carrier needs changing on the 3.08 threshold lower than 3.08 (numerically higher) all have the same carrier
numerically less then 3.08 all have the same carrier but a different carrier to numerically above 3.08 so depends what gears you have now but if going spool or full locker they replace the carrier anyway
