Wiring Corrosion Counter Measures
jdcaples
Old Time Jeeper
Seattle, WA
J0M93ECxxxx
J - Jeep
0 - Year 1980
M - 1980: 4-speed Manual
93 -Inches of Wheelbase?
E - 4150# GVW
C - 6 Cyl, 258 CID, 2 Bbl
Dana 300, SR-4, stock and rusting; I'm the fourth owner.
What you need is known as "potting compound", meant to seal junction blocks, bulkhead fittings and such. Dielectric grease on the connection side as well.
That's the stuff, JD. I have a new tube not 4 days old that will seal and attach the rubber rain seal to the top of my windshield. No more water blowing under the softtop corroding all the dash wiring and gauges.
I have the same stuff gluing a piece of foam insulation to the top of each valve cover as standoffs for the spark plug wires. Same goop insulates the wiring connectors on my boat trailer where repeated salt water immersion would soon dissolve the wires.
As best I can tell, the stuff never hardens and cracks like some other insulating material.
