Wondering what these bolts are for?
aceves6
Texas
1976 Jeep CJ5, 232...all I know thus far.
Hello, in looking at this pic can someone tell me what these bolts are for? I'm thinking at somepoint there was a tire carrier? I'd like to remove them and cover them up before I paint.
1976 CJ5 .
Let me know,
Thank you.
I would guess you'd be correct but I can't say with 100% certainty.
Looks to be an early 76 or 72-74 tub. The 4 lower bolt holes indicate you have a tailgate and not a rear fixed panel, in that case their for the tire carrier mount.
Yes you are correct, it does have a tailgate.
Thank you for your help.
Stock spare tire location. The big nut in the lowerer section is tapped and once had a big mushroom shaped bolt in it. It was where the tire sidewall bumped to reduce tire shake.
It looks like your tub has a WIDE selection on holes that don't belong as well. I'm a purest and would leave the holes that are factory correct. I would also get rid of the wide selection of bolts and go with the big headed stainless steel bolts with a philips head that are common in that area. One of the things that make the intermediates great are the quirky military left over notches and bumps.
Michael
$70.00
  35.0%
