YJ cage: Is there a gasket btwn. bars and windshield?
Deerejeep
Bettendorf IA
'81 CJ7 4 cyl. S4, d300 soon to be amc360 t18 D300. Restoration.
'08 JK 4" lift, 35" and on and on.
Family style roll bar going into a 81 CJ7 . The spreader bars appear to have a ridge
around the mounting holes so it does not sit flush with the windshield.. Do you
know if there is a gasket that sits between the bar and the windshield?
Not exactly sure of what you have, but a gasket would be a great addition to help prevent rust where there is metal to metal contact. I used a heavy rust preventative paint where my cage bolts in, but think a gasket would work better.
Putting the family roll bar in is next on my list. I would love to see pics of the problem and solution when done if you have the time :)
No gasket...However, when building out mine I used (actual) rubber undercoat on both mating surfaces. Actually, I do that for all hinges and mount plates (including the body armor) where metal lays against metal...paint wears away and moisture will start to rust. Been over 10 years since I did some of the parts...still no rust between mount points.
$35.00
  17.5%
