Misc. 1981 CJ build question
joeker81
Colorado, USA
None
I have been offered a 1981 CJ with 70,000 miles on the odometer. The engine has been changed from the 2.5 to the 4.2-6cyl. My question is if it came with the 2.5 engine, Will it automatically have been built with less capable running gear? ie, transfer case, axles? It has an automatic trans.
:welcome:
The entire drivetrain would be the same for all CJs in 81 except for the trans and engine options. A different gear ratio and Limited slip option could have been ordered also.
The diffs, brakes and transfer case is the same for all models.
The 4cyl 151 came with a tf904 auto and the 258 with a tf999
If you have a VIN you can check it here.
(BTW - if a word is in ORANGE when hovered over or clicked it links to related content)
Here is info on CJ7s
Unless it was originally a manual and someone changed that as well. When did they stop the quadra trac?
Quadratrac - 76-79
