TCase '76 CJ7 Quadra Trac vacuum line question
JohnEJo
Hello. I have recently acquired a '76 CJ7 with the quadra trac system. It is currently stuck with the e-drive engaged. I have turned the e-drive switch (in the glove box) back and forth to try and get it to disengage, and I have even tried multiple times doing a bunch of figure 8's, but all to no avail. I checked the vacuum lines and noticed a couple tares where they connect and cut those ends off and reconnected, but again to no avail. Since it has sat for nearly 10 years, and possibly much longer than that, I am wondering if I need to just replace the lines. I have not been able to locate replacement metal lines anywhere, and while I have heard of some just using rubber lines instead of metal I have been unable to identify what size tubing I need. Does anyone know what size tubing I will need to get for this?
Thank you.
Thank you.
